RCU Forums - View Single Post - Nitromodels PREDATOR RQ-1B
Thread
01-09-2013, 01:07 PM
965
papajeff
RE: Nitromodels PREDATOR RQ-1B
Whirl,
It's not so much physical size of the motor that matters, it's the wattage which you are aware of. Also,
the plane is so light in it's construction, all balsa, that I did need some extra weight in the nose battery
compartment to get the correct CG. You can see some of the little lead weights in these photos.
Also, I found it helped the air flowover the battery toopen a small hole in the nose as you can see.
Reply
Like
papajeff
View Public Profile
Send a private message to papajeff
Find More Posts by papajeff
View iTrader Profile
