RE: spun the teeth off my gear
yeah replace the gear lol... sounds like you didn't have the gear mesh set right, or the engine came lose and moved. when you set it, take extra care to check both gears inside and out, cause the outsdie one (forward facing) make look ok, but if the engine is tilted sideways, it may not be hitting the other gear, or vice versa.
