ORIGINAL: RCISFUN
igorcar
Eric and Juan will fix you up, my Cheetah takes 30 seconds from the command to start until the display says running.
There are only a couple of parameters that need to be adjusted
Can you advise what needs to be adjusted to reduce the long wait time? Mine does the same thing has gone through one starter motor already.
