RE: Battery Charger not working
Hi, welcome to RCU. I'm going to try to have this moved top the general batts/chargers section since this is specific to MRC brand. In the meantime would you try to fix your links? They aren't working.
Just on the surface your hot connector surely could be a problem. If the connector/adapter is dirty perhaps you can clean it with some motor spray or other contact cleaner?
