RE: GP Waco?
Is it me or is the engine off set to one side, because it doesn't look to mount on center to the firewall. Since I am using the DLE-20 I have to make adjustments to the mounting holes since none of the ones they have marked match up to my motor mount. I even went and bought the Hanger-9 mount like the one cannonball used, and even it doesn't match up to any of the scribed marks on the firewall. any comments on the matter. The rear mounted carb and location of the fuel tank makes it a challenge to routing the throttle linkage through the firewall as well.
Cannonball (Eddie) the Throttle arm on your carb were did you acquire it from.
