ORIGINAL: micah11
Im looking to put a new motor in my SC10e, I have stock everything, and am looking for an increase in speed. I would just be running it on the road, so heat shouldn't be an issue, right? I'd like the motor to be less than 35$, is it worth it, or should I just get a bigger pinion gear for speed?
what battery are you running in it right now? Running the Caldera with a 2s lipo and a 15 tooth pinion will make a noticeable difference in speed.
