RE: zero throttle but blades are still spinning...
same issue falcon40v2 2.4 . as soon as i plug the battery in main blade starts spinning. tx iis set to zero throttle. yes i did have a crash an snaped a main blade. should i change the motor(esc is mounted on the motor) or would it be in my receiver. thanks
