RE: Strimmer Engine CDI conversion,which Spark Plug
If the ignition can not spark normally through the spark plug, it will fire inside the sensor or even the ignition unit destroying it. Something is not correct about your circuitry?
Forget the CRRC unit. Thy went bad all the time for small wire that break,
