RE: Strimmer Engine CDI conversion,which Spark Plug
Thanks very much guy's for your help..
I fitted a new spark plug (BPMR6F)today along with a new hall sensor and after a little fettling about with the mixture screw the engine runs..The CDI unit is fine and appears to be working well...It starts first time by hand but I won't be doing that to often !!
The only minus I can see at the momment is it seems a little laboured so I may purchase another prop.I'm running it with a 16-8 atm so maybe a 16-6 will help..
Anyway a BIG thanks to you all for your help !!!!!!!!
MIKE
