RE: P-51B Mustang 32e ARF by E-flite
I started the build by cutting the motor box back 43mm from the front, keeping the right thrust intact. I cut a 1/4" piece of plywood and epoxied it in with triangle stock going back into the motorbox. After that dries, I will fiberglass over the air-cooling openings below the motorbox, and fuel-proof all the wood in front of the firewall.
