ORIGINAL: nitrosportsandrunner
ORIGINAL: Microz
nitrosportsandrunner - Ah okay thanks. What air filter oil did you use when you had your baja?
Foxy - Ah okay thanks that makes more sense now. Oh and about your part ''the lower the octane, the smoother they will run'' does this mean I do not have to use premium grade fuel and can just use the regular grade gasoline that most 1:1 cars run on?
IDK if it will run smoother, but there aint no need of running premium. Not unless its a really built up motor running higher compression. Stock motors wont run any better on premium than regular.
Okay sweet thanks! Oh and will regular 2 stroke oil I use in my weedeater work just fine for the oil : gas ratio? I know the ratio is probably different from my weedeater, but will I be able to use the same oil I use in that?
