RE: Real flight 6 folder locations
Normally when you import files, the simulator modifies the paths as the files are imported.
If you find that these have not been changed, make SURE you redirect your \USER\ folders in Windows to your D: drive.
This may require several registry hacks as Microshaft does not make it easy...
Given the availabily of SSD drives, it is a bit strange that they have not provided an easy way to do so.
