RE: Improved mods for MXZ
Thanks for the pics!!!!!
Like most people I have no patience and jumped right in about 2 minutes after my post for help....I got it all done ( it is easy if you notice that plastic is pretty thin and you can see the holes from the aluminum....might try to put some white paint pen on surface next one, should really show the difference!!!!)
I'm close but my front shocks are "grabbing" the arms so my upper mounts might be a little off, probably a spacer and I'm all set!!!
Any tricks for the drive spockets in the track???? ( I see that there's three nubs of plastic and you just drill out the centre hole/stem to match the shaft)
HF......REALLY, REALLY makes a nice kit!!!!! That front block for the suspension fits like a glove!!!!!
JC
