ORIGINAL: ALbert.S
Ihave a AR9020 with 2 remote receivers I bound the system and all worked well Turned it off and removed 2 remote receivers Turned back on without the remotes plugged in THE RECEIVER DOES NOT WORK WITHOUT REMOTES is this normal??? The remotes must be plugged into the plug they were bound with or they blink Is this normal ???
Yes that is normal.
