RE: Help!! A-10 brushless EDF motor issues
the first set of beeps is throttle range and zero setting. then there are more series of beeps corresponding to battery type, brake, etc. You need the prgramming data from Guami, now since the default values have been changed. Try this: 1. 100 percent on the throttle stick-tx power on-plug in flight battery 2. very first beep...immediately move throttle stick to idle...having the idle trim neutral...
