Help w/ servo elevation
This my second attempt at installing a servo for elevation in my tammy pershing...
I am using a 4ch Futaba 2.4 gHz w/ a fire button installed.
This is the sequence from the DMD to the servo.
Receiver > Dual Servo Extension Slot 1 > Tamiya Electronics Channel 3
Dual Servo Extension Slot 2 > 6" extension > Servo Rate Reducer > Micro servo
The elevation works fine.
The problem is when I fire, the servo "hops" a bit, enough to redirect the barrel.
I have tried to insert 1 or 2 more rate reducers in sequence.
The more I add, the less it hops when I fire.
However, with 3 rate reducers installed, the servo twitches the whole time.
Any thoughts?
