ORIGINAL: jayseas
HAS ANYONE HERE TRIED RUNNING A OLDER BRONZE BUSHED FOX .015 ON 1/2A BLADDER SETUP?WAS THINKING OF TRYING THAT ON A SCRATCH BUILT BALSA COMBAT SHIP LIKE THER LITTLE SATAN JUST ALITTLE BIGGER.ANY COMMENTS WELCOME.
JIM
I have older Fox .15's but never tried running them on bladder. Try it on the bench and see if the needle threads are too coarse.
Do not use the Li'l Satan. It is WAY too small and is designed for a tank mounted 1/2A engine.
For a .15 you need the Junior Satan. I had a MAX-III .15 on mine but the Fox .15 should work fine. I would suggest .012x52' lines.
Good luck with it.
George
