ORIGINAL: curtusua-RCU
ORIGINAL: jws_aces
Hey guys... what size TT P-51 style spinner is needed for the model?
Thanks...
Curt
I am pretty sure I got the 5'' from them. The P-51 style. I call them to make sure I got the right adaptors. They are very good at Truturn.
Jeff...
I am thinking of using the Rimfire motor as well and was wondering how you adapted the TT spinner to the motor shaft? Is the shaft drilled and tapped for a 10-32 bolt?
Thanks again...
curt
Jeff... I downloaded the motor's manual and see that the shaft is 8mm and threaded 1.25....
When you call Truturn there is a lady that will answer you questions and place the order. She knows her stuff. I can't remeber her name. I have order 2 different spinners and they know what you will need. I think it is about 160.00 for the set up but well worth it. The stock spinner is junk.
