I did a quick search for the motor and did not find much. Many motors are made in the same factory with different stickers on them.
I have (2) .46 sized brushless motors. I run them with 60 amp ESC's, 5s 5000mah batteries, 12X6 and 13X7 props. My motors pull over the 45 amps your ESC can handle.
If you have a watt meter, start with a 3s battery and see what that draws. What prop did it come with?
Watt meter is out of stock here.
http://www.hobbypartz.com/aeo-p0-watt-meter.html
Buzz
ETA SPELLING!!
