RE: DLE 30 replacement carb
Hi guys
Spent few minutes trying to explain my problem and I dont know what button I hit ,went out of my browser!!
so here we go again, I have a dle 30 rear carb with the original walbro like carb, never gave me a trouble since 2009 despite the normal rough rich idle, last week replaced all the gasket and diaphragm and it started to surge at 1/4 stick, so landed and adjusted the low end a bit reacher,and it got better, but still doing it a bit in different stick positions, so while I sort the carb out probably adjusting the fuel flow leaver, Im tempted to try a new walbro I found in my spares box, cant remember wy I bought it! anyway the problem is the carb is a WT-934 and I cant find much info about it to see if will suit the engine, the bore is bigger has a 32 stamped in the intake and has no choke which doesn't bother me,because I never use the one in the original carb, the engine after priming it a couple of turns fires up with an align starter at the first attempt.
So anybody know about this WT-934 engine application cons and pros?
thanks!
