RE: Easy Tiger Models Giant Warbirds Pros/Cons
the CG worked out to 5.5 inches infront of the leading edge . I'm using a DA85 for a power plant and have added about 8 pounds of lead so the weight about 30 pounds . Over all its a great flyer,although the gear isnt the best ,too much wobble in scissor,ended up pinning the strut and cured most of the problem,just reprimered the plane and used auto rattle cans and major decals. I also changed from the pull pull set-up for the tail wheel and rudder( I dont like pull pull)
Semper Fi,Mac !
