RE: Setting idle cut off and other
I have a 8uhp and you may set the three position switch as you said but I do not know.
Instead I use the trim lever for my "in the air, starting" idle;
the landing gear switch (upper left, opposite the three position switch) for my "landing" idle;
and the trainer switch (behind the landing gear switch) for my engine kill switch.
