RE: JC Experts please reply...
If the turbine use to start fine, but as you indicated lately you are having it hang, the first thing I would do is remove the gas line (with the restrictor) and then blow air back out the restrictor. That restrictor is the little brass thing in the yellow line. Sometimes they will get a partial plug and this limits your gas supply. Hope this helps.
