RE: realflite questions
If you can point me to the specs for your model, I can create an AV for you that should mimic your plane.
I'll need information on:
Actual RC plane, preferably a URL with all of the ARF/Kit specs, preferably including airfoils used.
Fuel Tank size used
Servos used and where ( to get their weight ).
Engine specs, preferably with static RPM test data for the prop you are using.
Engine fuel consumption.
Retract, struts and wheel weights
Prop size and pitch, and spinner used
Battery packs used and weights.
Any other items that may be adding more than 2oz of weight to the plane.
It also will be very helpful to get info on where your batteries are placed, where your CDI is located, etc... and anything done by you to adjust the or fine tune the C.G. I would also like throw amounts in degrees for all of your control surfaces.
