RE: Four Stroke concern...
It could be that your idle is too good, meaning that the LS needle is too lean, this will make the HS needle ineffective; creating the exact condition you're describing. Try backing the LS needle out about one half turn then bring the HS needle to absolute peak and then set the LS again.
