RCU Forums - View Single Post - Anyone EXTENDED their CEN GST? Check out this Chassis Kit....
Old 04-20-2013, 05:21 AM
hooleydog
My Feedback: (24)
Default RE: Anyone EXTENDED their CEN GST? Check out this Chassis Kit....
ORIGINAL: The Real Dogman
If you used the same brand servos you should not have needed to reverse the servos!! They rotate in the same direction to turn the wheels the same way. Have you driven that yet?
I not sure what you mean. If you use any other servo's they will move in the same direction IE: both will move push or pull. You want one to pull the steering link and the other to push it, as for it been driven yet nope. Though, All 3 diffs are from the GST nemesis, cos they use a larger out drive bearing. (GST 7.7) uses a smaller bearing. Infact the whole gearbox is from a GST Nemesis too
Mike..
