RCU Forums - View Single Post - Metal Steering Arm
Old 04-21-2013, 03:03 PM
jonty
jonty's Avatar
Default Metal Steering Arm
Hi all
I am building a 60 sized plane with an AMT (Fletcher FU24). The AMT is controlled via a 5/32 rod through the fuse. I need to fabricate or buy a linkage to attach to the 5/32 rod to which i can attach the push rod. I was thinking something along the lines of a heavy duty steering arm which has a grub screw. The only thing I can find is the Dubro 155 set up but it is nylon. Will this be ok with the forces on an AMT? If not any idea where I could get a good metal steering arm that is quite long?
