For the front macpherson suspension, I bought some used Team Losi XXX shocks, they have threaded body and I think I figured out a way of doing the struts and wheel hub/bearings attachment. No pics yet though. Should be pretty much like the real car, shock attached to hub at an angle of approximately 100 degrees, shock upside down (shaft up, body down) and I will use the shocks ride height adjusters to tighten the shock on the wheel hubs. It will be easier to explain with pics
