Old 05-25-2013, 10:28 AM
  #108
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
Here's how to seal the surface and get it ready for primer.
Wash the surface of the fiberglass with liquid soap and water. Dry the surface. lightly sand the surface of the model with 220 grit sandpaper used dry. Then dust the surface to remove any excess material.
Apply a layer of lightweight Spackle. I use a squeegee to apply the material in a thin smooth layer.
The fuselage had some larger holes that were filled with a polyester type filler. Let this dry and sand smooth.
Lightweight Spackle was applied to remaining surfaces.
Allow the surface to dry for a couple hours and then sand the surface smooth with 220 grit sandpaper used dry.
ID:	1885371   Click image for larger version
ID:	1885372   Click image for larger version
ID:	1885373   Click image for larger version
ID:	1885374   Click image for larger version
ID:	1885375   Click image for larger version
ID:	1885376   Click image for larger version
ID:	1885377   Click image for larger version
sahartman21 is offline
