Old 06-02-2013, 10:22 AM
  #112
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
I wet sanded the wing and tail surfaces and sprayed on another coat of red Acrylic Enamel paint.
The paint was allowed to dry thoroughly and then the surface was wet sanded again.
I used 2000 grit wet-and-dry sandpaper used wet.
Be careful or you may go through the color coat. I did and touched up the surface with a red marker.
ID:	1887938   Click image for larger version
ID:	1887939   Click image for larger version
ID:	1887940   Click image for larger version
sahartman21 is offline
