RE: Problem with EPA and aribrakes in T9CP
Hi, Manuel,
The 9C doesnot have "limiting end points" which is what you are expecting. that is a very complex, high end feature offered only on the 9z and a handful of other very high end radios.
you will need to adjust your setup so that full aileron does not over-deflect your servos.
is this model a glider? if not, acro programming may be an easier setup for you.
