RE: SD10G servo saver???
The deal is the FHSS3 RX's use the faster frame rate that the system is capable of. Anolog servo's do not always interput the data correctly from the fast rate.
It's a hit and miss issue, I had a cularis that I upgraded to a SD-10G and FHSS3 RX initally I thought I was ok but after a minute or so the servo's started going wild. If you want to use analogs then you absolutely have to ground test them for several minutes to assure you will not have a problem and even thne there coould be an issue later on.
When stepping up to the SD-10G and FHSS3 rx you really need to step up the servo's as well to digital.
In my case I back tracked to a FHSS1 8 ch RX and continued on with my Analog servo's. let me tell you this is a solid combonation. Range is not an issue. I gaurantee flying under visual line of site you will loose sight before you will loose signal.
