RE: Sebart's new pattern ship MYTHOS
Kevin,
How did you measure your CG ? - was it "ready to Fly"? - as Bo says your CG equates to 200mm from wing LE which is is much further forward than the recommended 215 - 225mm What's more you have no KE coupling !!
I have played with the CG - currently around 220mm & had it back as far as 225mm & still had a fairly severe KE Pull to the canopy (usually indicative of a Forward CG). My Mythos is 8S & a little heavier than yours but not by much (4610g with lightest battery) so I don't think this is a significant factor. I tried the UC fairings, they didn't effect the coupling at all, next I will try the wing SFG's
Steve
