RE: Sebart's new pattern ship MYTHOS
Kevin,
Thanks, yes I wish the wing incidence was adjustable, I need more positive as flying straight & level the tail hangs a little low.
CG does have some effect on the pull to canopy as when I tried a more forward CG the pull was worse but I agree changing CG is not the solution.
The pocket the wing root fits into makes adjusting wing incidence a pain, can be done but a fair amount of work required to achieve it
I may try dropping the ailerons a couple of mm to simulate increased wing incidence.
Steve
