RE: Jetti Pro Spin 99
A little more re the fixed end points:
Initial point:
Check how low your particular Jeti box can go- Mine is 1.00 msecs. Set your Tx lowest throttle point (on the travel adjust or whatever it's called on your brand) to be 1.00msecs,using the pulse-width measuring on the jeti box.(Leave the trim alone, I leave mine at the mid-point).
High point:
Set your high throttle travel adjust at 100%, and again measure the pulse width, and copy this onto the jeti box setting (it's usually around 1. 9 msecs) If you wish, you can widen the total travel by increasing the the high travel adjust to more than 100%, provided the jeti box can replicate the length of the pulse).
To arm:
Turn on Tx with low throttle set as above.
Turn on Rx,and then the motor connection.
The ESC will not arm just yet.
Now return to the low throttle travel adjust, and lower it one (finest) step at a time, until you hear the single arming beep.
Don't forget to rebind at these settings.
Now, provided you have the "set thru RC" turned OFF, you can only re-arm at these settings, which will remain consistent. In fact, the ESC won't arm at any other, higher, throttle setting at switch on.
