Old 06-22-2013, 02:55 PM
  #169
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR-6 Construction Thread
The primer was lightly sanded with 220 grit paper used dry.
Use a tack rag to remove the dust from the surface of the wing.
The wing was then sprayed with Acrylic Enamel paint.
Later Note: If done again I would sand off more primer. I left too much on the wing and it was a little heavier than desired.
ID:	1894103   Click image for larger version
ID:	1894104   Click image for larger version
ID:	1894105   Click image for larger version
sahartman21 is offline
