RE: HK-450GT CCPM Alloy T-Rex compatible - Part IV
Turns out I only had a few kilobytes of memory left.
Deleted previous videos from it and it should be all good.
Putting the helis aside for a while and got round to fixing my quad. Mainly re fitting the shaft in the motor bell, balancing some props, balancing the motors and fixing the frame.
I am also hoping to make some landing gear for it.
Also I found another way to attach the props to the DT750 motors that I was using. Instead if using a combination of props and locknuts, even some threadlock, some ziptie the prop directly to the motor bell. Sounds weird, but I hope it will actually secure my props!
