ORIGINAL: Kozzy_98
Turns out I only had a few kilobytes of memory left.
Deleted previous videos from it and it should be all good.
Putting the helis aside for a while and got round to fixing my quad. Mainly re fitting the shaft in the motor bell, balancing some props, balancing the motors and fixing the frame.
I am also hoping to make some landing gear for it.
Also I found another way to attach the props to the DT750 motors that I was using. Instead if using a combination of props and locknuts, even some threadlock, some ziptie the prop directly to the motor bell. Sounds weird, but I hope it will actually secure my props!
I've had that happen..... always right when your at the field. Formatiing the card is good to know when your at the field and you've run out of space
Try a set of 500 landing skids for your quad. I see they are popular.
