RE: Jetti Pro Spin 99
Hey Chad,
That is almost identical to what my settings ended up, after testing yesterday. I am trying to figure out the end points high and low now (14MZ). The only difference I see, is the cells, volts and cutoff cell voltage at 2.8. I did turn the RC back on, but I will turn it back off. I was at 2880 Watts and now I'm at 2550, so something has changed, being my end points and the throttle curve.
I flew the P a few days ago 8 minutes including some extra stuff the one last minute. The battery was a 9 percent , normally, I'm at 33 percent on average at the end of a P. It was a 9 percent because I had to keep feeding the motor, more like full throttle which is usually half throttle to achieve the same. All three packs I'm flying are new with about 30 flights now.
Thanks Guys,..I'll keep working on it.
Bill
