RE: AR-6 Construction Thread
Scott, I'm curious about your use of peel ply as a hinge. i do realize there are dozens of peel ply products out there, some being treated with release and some not. It however still leaves a question in my mind as to how the hinge holds up in the long run? Everytime I use peel ply it seperates from the fiberglass laminate rather easily and that is exactly why I use it as a release barrier between breather and laminate when I vacuum bag. Is there something special about what you use as I would like to try this hinging method.
