RE: PRO X 260 Assemb/Build Thread Gas Engine
The pics below show cutting out the fuse with a scroll saw. Then I followed up with a sanding drum on my Dremil to get a final fit. The rest of the pictures show various angles as I was fitting the engine. This was out of sequence with the manual as I wanted to fit the engine prior to installing the stab and rudder. It made the assembly easier to handle without risk of breaking a tail feather. I need to mention that I placed two washers, one each under the front engine lugs between the engine and the model to give the engine about a two degree right thrust per the manual.
