Old 07-13-2013, 02:20 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Candy Kane Build Thread
I used the Sam-Rai wingtip as the pattern.
Trace the pattern onto contest grade (very lightweight) balsa.
They were cut out using the jig saw and were glued on using Gorilla glue.
Wet the surface with water prior to applying the glue.
Tape the wing tips in place.
I applied a little too much glue and it foamed outside the joint.
It is easier to remove the extra before it dries
ID:	1900170   Click image for larger version
ID:	1900171   Click image for larger version
ID:	1900172   Click image for larger version
ID:	1900173   Click image for larger version
ID:	1900174   Click image for larger version
ID:	1900175   Click image for larger version
sahartman21 is offline
