RE: Raptor 30- Spektrum AR600 W/ blinking red light
Interesting...
If you have another receiver then I would certainly give it a try, at least for a range check.
If they both have the same then I'd take a peek inside the transmitter, the little coax connector that hooks the antenna to the board is somewhat fragile and the pin could be bent over inside it or it could simply be loose.
