RE: DLE 30 ignition voltage
If your using an RcXcel ignition, you need to use a 4.8 pack. The capacity is up to you, but the more milliamps the better, I use 2500 with no problems at all. The use of an NGK CM-6 plug or Honda equivalent is highly recommended.
