RE: Transmitter won't charge my battery
Thanks for all the suggestions guys but as I said in my original post:
Battery is same 8 cell 9.6v
I've tested the charger at the connection end and its giving voltage.
I took the back off the transmitter and tested the circuit board where he power comes in (without batt attached) and got the voltage fom he charger. It goes to a small board where the aerial and crystal module also connect. From that point the feed goes into the main circuit board and I don't want to take hat out. I'm guessing the transmitter is at fault.
The new battery had around 10.3v when I bought it and its now at 10.1 despite trying to charge overnight.
