RE: Sig LT-40 Crash
Found out it will be a little more than a few hours work. The firewall did come loose from the body and I'll have to replace the frame fwd of the wing. Also on the wing the joint were the two sides come together is loose, the hinges for the ailerons on one side need replaced, and both pins need reattached. Here are a few more pics after I started the rebuild.
