RE: New DLE 35
It could be the carb or the ignition. Can you strap on an ignition module from one of your other gas engines to see if that is the problem? You do not need to put in inside the plane, nor do you even need a switch. You can just tape it to the LG along with a known good battery, use the battery plug for your ON/OFF switch. Don't fly it like that, just use it to get the engine running. An RCEXL A-01 type will work in place of the A-02 that came with the engine.
