RE: New DLE 35
I sent my bad ignition module in to the repair service in mid-May and they have not sent a replacement yet, they say it will be in by the end of this month. There seems to be a shortage of the A-02 modules right now. I'm running one from my other gas engines.With the bad module, my engine would start okay and the idle was good if low (below 1500), but the spool up was very slow and erratic.The module will pass the tests that only check for spark at the plug with the Hall sensor simulator and the spark at the plug will appear to be normal.Do you have an ignition module you can swap or maybe borrow from someone to make sure yours is really bad?
