I have my new A0-2 module back from the repair shop. The engine runs, but will not spool up as fast as the A0-1 module and will frequently die if the throttle is advanced too fast.
For you math wizards out there, here is the raw data that I measured. Can one of you convert the time delay, from the Hall sensor to plug fire at the RPMs shown below, into Degrees before or after TDC? I did it and I find the results hard to believe, it looks like the timing is still messed up; just wondering if I made a conversion error.
<colgroup><col style="width:48pt" span="2" width="64" /> </colgroup> RPM | mSec |
500 | 8.2 |
750 | 4.8 |
1000 | 3 |
1250 | 2 |
1500 | 1.2 |
1750 | 3.6 |
2000 | 3.2 |
2250 | 2.6 |
2500 | 2.1 |
2750 | 1.61 |
3000 | 1.2 |
3250 | 0.98 |
3500 | 0.58 |
3750 | 0.36 |
4000 | 0.2 |
4250 | 0.01 |
