ORIGINAL: lomcevac540T
Is there any way to put a small gas engine in this airframe?
This plane is designed for electric power only. If you were to install a glow or gas engine i think the vibration would shake it to bits in no time.
You would have to do quite a bit of strengthening and reinforcing which would add a significant amount of weight. Even then you can't get inside the wings etc. which may not be strong enough to cope.
I'm hoping they will release an IC version in this size.
